80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
  • Advanced circuitry design, built-in speakers protection circuit, solid aluminum chassis for long time use, small size, good looks, simple functionality, and excellent sound quality;
  • Best for bookshelf/computer/desktop/speakers in your room, connect to your Phone/MP3 player/DC/TV/Echo Dot as input, 50W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD) can drive 2Ohm - 8Ohm speakers;
  • Simple compact design but practical and powerful, Adopt TI TPA3116D2 chip to get clear and clarity sound, no audible noise, dead silent when nothing is playing through it;
  • Aluminum shell and Aluminum knob to sure high quality come to a 19V power supply that can fit with the amplifier well. 24-month warranty, you can return the item if you have any problems;
Fosi Audio V1.0G 2 Channel Stereo Audio Class D Amplifier Mini Hi-Fi Professional Digital Amp for Home Speakers 50W x 2
Model V1.0G
Chip Set TPA3116
Output Power 50W x2@4Ω
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Speakers
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
DC Input Range 12-24V
Power Supply 19V 4.74A
Fosi Audio V1.0G Amplifier x 1
19V 4.74A Power Adapter x 1
Video
Compare with similar items
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
