Black Friday Exclusive Offer
Why Choose BT20A PRO?
- The Best Mini Stereo Amplifier
- Great for desktop‑hi‑fi & office/home
- Output Power: 300Wx2 @4Ω
- Terminating Impedance: 2-8Ω
- Input Mode: Bluetooth + RCA
- THD: ≤0.005%
- SNR: ≥108dB
- Chip Set: TPA3255
- DC Input Range: 24-48V
