Knobs designed for subwoofer
Pre-Out Connector
  • 2.1 Channel Amplifier: The BT30D PRO integrated amplifier features two sets of passive speaker outputs and one set of passive subwoofer outputs, making it easy to set up a 2.1 home theater or other stereo HiFi audio systems.
  • Exquisite Craftsmanship: This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well-designed case, along with the high-quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
  • If you plan to use a 48V power supply, active cooling (such as a fan) is required to ensure stable operation.
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From €109,99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
From €89,99
From €89,99
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
