  • Easy to set up, no special software, app, or driver to install, a true plug-and-play digital audio adapter.
  • With USB, optical and coaxial S/PDIF inputs can fit with most home audio systems, and RCA output can be connected to an amplifier or powered speakers on your desktop;
    Built-in Hi-Fi headphone amp chip can drive most 16ohm to 200ohm headphones.
  • 160mW RMS(32 ohms, 20 Hz - 20 kHz, 0.01% THD), with bass and treble control, can be used as preamp or volume controller for your PC/MAC/Computer.
  • Mini Compact D/A converter, stream bit-perfect 24bit/192KHz HD with low jitter, with output, protect the circuit, safe for your expensive audio system.
Model Q4
PC-USB supports input sampling rate 24Bit/96kHz
High and low sound adjustment range ±6dB
Fiber/coaxial support input sampling rate 24Bit/192kHz
Frequency response 20Hz-20kHz (±3dB)
PC-USB support operating system XP/W7/W8/W10/MAC/Linux
Distortion 0.01%
SNR ≥105dB
Amp output maximum power 100mW 32Ω load
Headphone matching impedance 16Ω-200Ω
Working voltage DC5V
RCA output level 2.3V
Size (L*W*H) 73.5*98*33MM (without knobs and terminals)
Package Include
Fosi Audio DAC-Q4 x 1
5V USB Power Supply Cable x 1
PC-USB Cable x 1
Optical Cable x 1
Compare with similar items
Q5 Mini Headphone Amplifier
Q6 USB HiFi DAC Headphone Amplifier
Q7 Bluetooth 5.0 Hi-Fi Amp
  • 5 stars: 26 (100%)
  • 4 stars: 0 (0%)
Eugene R.I.
Perfect size and great sound. Highly Recommended
I use a CD player in my office with a pair of headphones. Wanted a small DAC/headphone amp to improve the sound and give me more volume out of the CD player. This unit perfectly serves my needs and for a good price.
E. R. Reid II
Adrian Scoffoni
Small & Versatile
The Q4 was a fantastic surprise. Not only does it offer all the basic needs and connections of a dac, but it also offers control knobs for bass, treble and volume. This feature made me buy it without hesitation, even though I had never purchased anything from Fosi Audio before. Something wonderful for me that I’m a fan of vintage audio systems that offered that kind of controls. 100% recommended!!
Adrian Scoffoni
Small & Versatile
The Q4 was a fantastic surprise. Not only does it offer all the basic needs and connections of a dac, but it also offers control knobs for bass, treble and volume. This feature made me buy it without hesitation, even though I had never purchased anything from Fosi Audio before. Something wonderful for me that I��m a fan of vintage audio systems that offered that kind of controls. 100% recommended!!
Jonathan V.
Q4 DAC setup works great
Very pleased with sound quality I am using the Q4 DAC as a pre amp with a Bt20 pro as the power amp, connected to a set of JBL control 1 Pros and a Cambridge audio Sirrroco Sub woofer, they all work great together even Deepseek agreed it was a great match, I mostly play music via the Optical link to my Samsung 50 inch TV. HIGHLY recommend it Fosi products they have brought my music listening to life again. I created this setup as an alternative to a streaming amp which are usually to expensive. I am looking forward to hearing about the Fosi S3, but will probably be out of my price range, as apart from the Q4 all the other components where purchased preowned.
Thanks again to the Fosi team.
Regards Jonathan
Jonathan Varty
Regards Jonathan
Ethan Nowacinski
Fosi Audio Q4 Desktop DAC Headphone Amplifier
Ethan Nowacinski
Customer
Superb Addition To Your PC Setup...
I've used this for many months now and it's worked flawlessly. The sound quality is excellent and it delivers as promised, a "no-nonsense" desktop headphone amplifier. I would buy this again!
Joe Bavlsik
Bob Wilson
Solid for my needs
Fosi Audio is paired with Beyerdynamic TYGR 300R and works for my needs. School/gaming
Bob Wilson
Solid for my needs
Thomas Long
Good Product and Excellent Customer Service
I was looking for a way to boost amplification on my TV headphones. I wrote to Fosi customer service and received a long, clear, and helpful reply, telling me which product I needed and how to hook it up. I followed the instructions, and the Q4 DAC Amplifier works like a charm. Good equipment, and excellent customer care
Thomas Long
Derick Cunningham
Derick Cunningham
Ted Peacock
Nice sounding DAC
I used this DAC for my laptops USB output then in a pre amp and then the ZA3. An analog path is such a better and more dynamic sound then the very limited BT transfer. I also enjoy how Fosi has made the input selectors on most products a physical switch. Much more reliable and no mistaking what input I'm on.
Ted Peacock
Nice sounding DAC
Gelu Stefanescu
Excelent little device
Sound clarity without any unwanted noise
Gelu Stefanescu
Christian Cesar Teston
I can't evaluate it because I haven't received it at my home yet.
Stephen Kincaid
Wowser
The clarity and the connection is perfection. This is such a dynamic little gadget. I use it every day with my headphones to go to another land of Bliss.
Stephen Kincaid
Wowser
HECTOR APONTE
GOOD!!
HECTOR APONTE
GOOD!!
