  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From €199.00
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From €139.00
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From €209.00
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From €109.00
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
  • 5 stars: 201 (87%)
  • 4 stars: 30 (13%)
Vittorio Raho
Sto usando il Fosi Audio ZD3 da qualche giorno e sono estremamente soddisfatto. Il suono è dettagliato e trasparente, senza alcuna interferenza o rumore di fondo. L'uscita offre un segnale preciso e dinamico. Esteticamente è solido, compatto e fa un'ottima figura sulla scrivania. Rapporto qualità/prezzo imbattibile!
John Skelly
A noticible upgrade to a cheap DAC
The Fosi Audio ZD3 is a noticeable step up in sound quality, delivering a cleaner and significantly more dynamic sound than my old DAC. It does a brilliant job as the dedicated DAC for my Merak CD player. Running it balanced into the matching Fosi ZA3 amp integrates the two units perfectly, resulting in a lively and engaging listen.
ALEXANDRU CHISCAN
Ordered ZD3 after noticing that the Fosi Audio BT20A Pro Bluetooth Stereo Power Amp DAC was not so great. Now, the ZD3 + BT20A Pro combination sounds great.
Andr��s C.
A fantastic DAC with balanced outputs and premium sound
The ZD3 has been a perfect match for my ZA3 amplifier. Setup was quick, and everything worked immediately through the balanced XLR outputs.
The sound is clean, transparent, and highly detailed without becoming harsh. The DAC provides excellent instrument separation, a wide soundstage, and impressive dynamics. Bluetooth performance is also surprisingly good for casual listening.
I also appreciate the solid aluminum construction, responsive remote control, and intuitive interface. It feels like a premium product at a very reasonable price.
If you're looking for a balanced DAC to pair with the ZA3 or any quality amplifier, the ZD3 is an excellent choice.
Phdejo
Ordered the ZD3 and ZA3+48V/5A PSU (no Op-Amp rolling), dug up my Monitor Audio Studio 10’s from good 30 years ago, added Fosi’s XLR cables (30 cm) and GEARit Premium Braided Speaker Wire (4.57 m, 2 x 2.5 mm2/14AWG, black), connected my iPhone 16 via Bluetooth and already enjoyed the results. These things are tiny, fit easily on top of one of my speakers and are a beauty to behold. Monitor Audio was the first British speaker company to offer metal-dome tweeters (aluminium/magnesium and gold-color anodized finish). The woofer uses an aluminium-alloy cone. It all sounds neutral, has a smooth treble, excellent soundstage depth, and a good feeling of low-frequency authority. In my living room of about 16 m2 there is nothing to be ashamed about. My first digital setup. I’m a happy camper.
Zdenek Skoda
I have been a Fosi Audio fan for a couple of years, and their gear is in my daily listening. My first piece was the ZA3, bought at launch, and it was my first real step into Hi-Fi. Since then I have built up to the full Fosi stack, ZD3 into ZP3 into ZA3, all running Oracle II op-amps, paired with my own 3D printed speakers. My passion is drum and bass, so that is how I judge everything. This setup delivers raw, deep, clean bass into the low 30 Hz range with no subwoofer, and it still makes me want to dance every time. It is remarkable what sound is possible at these prices, and it is exactly why I keep coming back to Fosi, quirks and all.
ZD3 (DAC)
A well designed DAC with amazing sound and build for a fair price, wide connectivity, and simple operation. It opens up easily for OPA rolling. A fun little unit that is absolutely worthwhile.
Plus
- Astonishing sound and nice build quality for the price
- Easy OPA rolling
- Wide connectivity, clean chassis design
- 12 V trigger
- Great customer support
Minus
- The stock power supply is weak, a linear supply is worth the upgrade
- The knob grips the shaft very tightly, so the first few removals are a struggle
- Same Oracle II caveat as the ZA3. Great sound but not fully compatible, with occasional artifacts and a limited lifespan
p
phdejo
Ordered the ZD3 and ZA3+48V/5A PSU (no Op-Amp rolling), dug up my Monitor Audio Studio 10��s from good 30 years ago, added Fosi��s XLR cables (30 cm) and GEARit Premium Braided Speaker Wire (4.57 m, 2 x 2.5 mm2/14AWG, black), connected my iPhone 16 via Bluetooth and already enjoyed the results. These things are tiny and fit easily on top of my left speaker. Monitor Audio was the first British speaker company to offer metal-dome tweeters (aluminium/magnesium and gold-color anodized finish). The woofer uses an aluminium-alloy cone. It all sounds neutral, has a smooth treble, excellent soundstage depth, and a good feeling of low-frequency authority. In my living room of about 16 m2 there is nothing to be ashamed about. My first digital setup. I��m a happy camper.
Hitesh OSHO ?? MUSIC
Great Full Sound Stage Music
I had never heard a sound like this before hearing this��and installing the Sparkos SS3602 in it has truly been the icing on the cake.
Kent Roger
ZD3 an absolutely fantastic product.
I absolutely love the ZD3 and the service from Fosi. Just ordered the BOX X5 as well now.
Jason Anderson
Good purchase
Works great as a dac/preamp for my Dayton audio hta200. The ZD3 gives me remote volume control for the Dayton. Anyone who owns the hta200 knows that the supplied remote is useless! I perceive the ZD3 as improving the sound as well!
Peregrine
So far so good
I��m still early in the process of returning to Hi-Fi. My ZD3 arrived nicely packaged and in perfect condition. Instructions were very clear and I had no trouble connecting it to my Fosi preamplifier and amplifier. So far I��ve been using it to connect via Bluetooth to Spotify on my iPhone with great success. I bought a cheap iPhone 13 camera adapter and attempted to connect to the DAC via USB, but failed. Either this is due to a faulty adapter or fundamentally not possible. I��ll sort it out. Meanwhile I��m going to try connecting a CD player via fiber optic as an alternative to Bluetooth. I��m also on the hunt for a vintage turntable. I��m enjoying this project immensely.
Perry Boggs
Fosi Audio ZD3
I ordered me a new ZD3 DAC and can't wait to give it a test drive. I read ALL the reviews and it was rated "Top Shelf" and after reading all the info and tech data, it was an easy choice PLUS, they gave me a nice little discount for being such a nice guy (not really). I should have it in hand in a couple days along with 1TB drive with ALL DSD music files my bro hooked me up with. I'll give another review once I get it up and running. No need for the tiny amps though as I run 2 Phase Linear 2 channel amps pushing 500WPC and 350 WPC, a custom built Carver Pre. I build all my own equipment but a DAC is out of my wheelhouse. Can't wait. Very cool looking too
Sanjay Jairathh
Melodious. Superb. Economical.
ZD3 + ZA3 = Excellent. For bit perfect audio my configuration is like this. Mac Mini M4 USB out to ZD3. ZD3 XLR out to ZA3 XLR In. Subwoofer connected to ZAR sub out. Controlling audio through ZD3. Sparation perfect, Vocals Perfect. I love stereo sound. Vocals comes from centre, one can identify all instruments playing in the song. Better than my Marantz 5004 AV Receiver combination.
Ian L
Extremely pleased
This is my first hi-fi system after 20 years soundbars and one box items.
I chose the ZD3 after seeing multiple positive reviews and matched it with ZA3 amps.
It integrated seamlessly and I'm delighted.
GB
good price/value rate
Petter Fredriksen
Super quality and sound
I got this recently and tried it and the quality and sound is great. Would recommend
Tony P
ZD3 DAC
Perfect match with ZA3
cons: remote is looking ugly.
Mois��s abad
Auriculares
Se puede conectar por Bluetooth a los auriculares el fosi zd3 o tengo que comprarme tambi��n el fosi zh3 que tiene salida de auriculares.. otra pregunta no interfiere el altavoz de la TV, yo con fosi auriculares y mi mujer con el audio de la tele viendo una peli.. esque soy un pelin sordo y para no subir mucho la tele..
David
Amazing dac, better price.
This is an absolute steal for less than two hundred.
Balanced outputs, 12v trigger, remote, hdmi arc, good dac chip, easy to read volume display.
Do yourself a favor and get it. I use it to feed my za3 xlr input and love it!
