Built on User Voices
  • Input: RCA x2 and XLR
  • Output: RCA, XLR, SUB
ZP3 & P4 Comparison
Channel: 2.0
Input: RCA x2, XLR
Frequency Response
XLR/RCA:
20Hz-20kHz (±0.2dB)
80Hz-20kHz (±0.2dB)
120Hz-20kHz (±0.2dB)
SUB: 20Hz-200Hz (±0.2dB)
Balanced Output (XLR)
SNR: ≥ 112 dB
Dynamic Range: ≥ 112 dB
THD+N: ≤ 0.0007%
Noise Floor: ≤ 6μV
Single-Ended Output (RCA)
SNR: ≥ 115 dB
Dynamic Range: ≥ 115 dB
THD+N: ≤ 0.0008%
Noise Floor: ≤ 4μV
  • Fosi Audio ZP3 x 1
  • IR Remote Control x 1
  • AC 110-240V Power Cord x 1
  • 12V Trigger Cable x 1
  • User Manual x 1
From €199.00
Fosi Audio ZP3 Preamplifier
Preamp
RCA x2, XLR
RCA, XLR, Sub-Out
Bass & Treble Control
≤ 0.0007%
≥ 115 dB
From €109.00
Preamp
RCA x3
RCA, Pre-Out
≤ 0.003%
From €99.00
Preamp+Headphone Amp
≤0.02%
≥103dB
  • 5 stars: 65 (83%)
  • 4 stars: 13 (17%)
Andrievs Niedra
Awesome product. Currently on a basic setup.
Might play around with op-amps later.
Awesome to have XLR connections.
Zdenek Skoda
The last piece I added, and my first pre-amp. At first I did not get the point, a DAC and amp already sounded fine. But a pre-amp adds flavour and signature, plus the ZP3 has tone control. At first it seemed dull, until I realised the tone knobs default to the middle. Once I centered them and did an OPA swap with the treble slightly lowered, it gave me the best drum and bass I have ever heard. Worth it? Without a doubt.
Plus
- Clear step up in presentation, stereo imaging and sub bass
- Handy tone control, three inputs, OPA rolling
- Solid build and amazing value
- 12 V trigger
- Great customer support
Minus
- The power button that also switches inputs feels cheap and clunky, a real step back
- No official disassembly guide exists anywhere, even though the manual talks about OPA rolling
- And the ZP3 is genuinely hard to open, tedious and easy to damage, as I found out. Fosi should fix this
Gibralthor
A Gem, Op-AMPs rolling
For those audiophile, if you plan to use the Dual Staccato op-amp
it does not work with the ZP3.
ERIK
Amazing
Running the ZH3 DAC into the ZP3 followed by dual ZA3��s in mono, Polk ES15��s and a Dayton powered sub. XLR connections and 12v switching. The sound is insane. Stick with neutral speakers like Polk, and you will hear music in your home in a way you likely have not before.
Massimiliano DI SILVESTRE
Un upgrade necessario
Ho acquistato il FOSI Audio ZP3 Preamplifier per sostituire il precedente FOSI P4 Mini Preamplifier in quanto ho espanso il mio impianto e avevo necessit�� di una uscita per il subwoofer attivo (FOSI SW10), che il piccolo P4 non aveva. Posso dire che la qualit�� generale del prodotto �� ottima e in linea con gli standard a cui FOSI ci ha abituato. Per quanto riguarda la versatilit�� e funzionalit�� del prodotto ovviamente �� quasi perfetto per le mie esigenze. Avrei preferito ci fosse anche un ingresso ottico, magari in alternativa all��ingresso bilanciato o comunque da selezionare con un commutatore sul retro. Per il resto la qualit�� del suono a mio avviso �� molto simile al precedente P4 e, in considerazione del prezzo pagato mi reputo soddisfatto delle prestazioni fornite.
Aaron M.
Secret Talent of the ZP3
What not many are talking about is how exceptional this preamp is at converting balanced to unbalanced and vice versa . I originally bought this for my main hifi but it added unvetted cables to my perfect synergy chain and ended up removing the ZP3. I almost sent it back when I tried it on my desktop system where I was using the streamer's DAC to feed desktop speakers. I used the ZP3 to pull balanced line out of my R2R headphone DAC to my speakers' single ended inputs. Subtle improvement, but that slight change was enough to make the sound more convincing and allowed my speakers to disappear so I can just hear the music like in my main system and headphones.
Enrique.O.
Magn��fico pre-amplificador.
En combinaci��n con una etapa Hegel H20 y unas cajas artesanas basadas en Davis Acustics y, como fuente Eversolo DMP A6 M��ster Edici��n (Streamer, mini disc SONY, CD EMOTIVA) todo cableado balanceado. Resulta un conjunto medio alto, con una claridad, definici��n y profundidad que hace las delicias de cualquier audiophil.
Louis T
Excellent addition to my Fosi setup.
Running a set of ZA3��s with a ZD3 and a P5 phono pre. The ZP3 is quiet, dynamic, and noticed a wider soundstage when introducing. Very happy with the product, thank you.
Nikolai Lyraan
Good
I tested this out from a friend and I was suprised by the connectivity and quality, would recommend to anyone wishing to get into Hifi
PotetBananSkall
Looks great works greater
I bought this ZP3 preamp recently and i was pleasantly surprised by the quality it has. The quality and versatility is great and I recommend it to others
Zoky
Fantastic sound
I have a ZP3, two ZA3s in mono mode and a ZD3 Dac.
Fosi devices are fantastic. The sound they provide is excellent. I am very happy. Thanks Fosi.
ZP3
Odlicno, verovatno najbolje do sad pretpojacalo od Fosi.
Potpuno balansirani, izvanrednog zvuka, idealno za seriju Z: ZD3, ZH3, ZA3
Iskrena preporuka
Eduardo Vargas
Impresionante producto, muy contento
Realmente sorprendido con la calidad de este producto, cumple con todo, se nota la calidad de los acabado
Cesar
ES mi primer equipo separado. Lo tengo acoplado a dos amplificadores V3 mono y un DAC ZD3. Me gusta el rendimiento, lo tengo conectados por XLR. Lo ��nico que podr��a pedirse es alg��n indicador lum��nico de volumen. El control puede controlar otros equipos de la marca.
Marquitta Schinner
Darrin Towne
Hreinn J��nsson
Ilse Langworth
They have faced a problem due to duplicate shipping and have behaved super well. At the moment, we don't know what the error was.
Sidney Hudson
Fast delivery, satisfied. I am using the Eversolo DM6 product and have not yet connected the additional preamplifier due to lack of experience. Therefore, it is difficult to comment on its performance, but based on user reviews, it seems satisfactory.
Ray Ullrich
Very good, I like the performance too. It's convenient because it has both trigger and output.
C��sar
Excelente presentaci��n
Vamos a probar todo el conjunto.
Krzysztof ?opusiewicz
comfortable
'- the preamplifier is "transparent" - with factory settings
- I don't use subwoofer - I left the high-pass filter open
- I connected two ZA3 amplifiers to the preamplifier using XLR - this is a very good set
- I use the eversolo DMP A-6 gen 2 as a source
- thanks to ZDA3 I could turn off the preamplifier in eversolo
- which gave a surprising effect
- now the sound is very juicy, powerful and direct
- and the operation of the set has become simpler and very traditional, simple and old-fashioned
- Since the ZDA3 has a high-pass filter, I am considering buying a subwoofer for my system
- this is the next stage'
