High-Res Bluetooth Audio
  • Max Output Power: 300W × 2 @ 4Ω
  • RMS Output Power: 180W × 2 @ 4Ω
  • SNR: ≥ 112 dB
  • THD+N: ≤ 0.003%
  • Channel: 2.1
  • Chipset: TI TPA3255, NE5532
  • Input: RCA1 / RCA2 / Bluetooth
  • Output: Speaker Out / Sub Out
  • SNR: ≥ 112 dB
  • THD+N: ≤ 0.003%
  • Terminal Impedance: 2–8Ω
  • Bluetooth SoC: Qualcomm QCC3095
  • Bluetooth Device Name: Fosi Audio BT20A MAX
  • Bluetooth Version: 6.0
  • Bluetooth Connection Range: ≤ 15 m (50 ft)
  • Bluetooth Audio Codecs: SBC / AAC / aptX / aptX HD / aptX Adaptive / aptX Lossless / LDAC
  • Frequency Response: 20 Hz–20 kHz (±0.5 dB)
  • Voltage Range: DC 32 V–48 V
  • BT20A Max Power Amplifier x 1
  • Bluetooth Antenna x 1
  • User’s Manual x 1
  • IR Remote x 1
  • Power Adapter x 1
Which Amp Is Right for You?
From €79,99
Fosi Audio BT20A
Release Date
2020
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3116, NE5532
Max Output Power
100W × 2
Inputs
RCA, BT
Outputs
Speaker Out
≥ 98dB
≤ 0.5%
Input Switch
Auto Switch
Bass & Treble Control
Supported
Bluetooth
5.0: SBC, AAC
Other Features
From €89,99
Fosi Audio BT20A Pro
Release Date
2023
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3255, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA, BT
Outputs
Speaker Out
≥ 108dB
< 0.005%
Input Switch
Auto Switch
Supported
Bluetooth
5.0: SBC, AAC
Other Features
From €239,99
Release Date
2025
Channels
2.0 / 2.1
Bluetooth Chip
Qualcomm QCC3095
Amplifier Chip
TI TPA3255, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA1, RCA2, BT
Outputs
SUB Out, Speaker Out
≥ 112dB
≤ 0.003%
Input Switch
Dedicated Switch Button
Supported
Bluetooth
6.0: SBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Lossless, LDAC
Other Features
Remote Control, PFFB Technology, Bypass, High-Pass Filter, 12V Trigger, Motorized Potentiometer
What functions does the remote control support?
The included IR remote can reset Bluetooth, switch inputs, control music tracks(in Bluetooth mode), and even control other Fosi gear(P4/ZD3/ZP3).
What should I do if someone else is connected to the amplifier via Bluetooth?
Press the RESET button on the remote to instantly drop the current connection, and clear the historically connected devices. Then pair your own device fresh (No Bluetooth reconnection function).
Can I listen to three audio inputs(Bluetooth and dual RCA inputs) simultaneously?
In TONE mode, the EQ controls are active, it can adjust the sound by treble and bass control. In Bypass mode, it bypasses the internal EQ, including treble and bass adjustments, to preserve the original audio signal output.
