Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
From €89.99
RCA/Bluetooth
Bluetooth Codecs
SBC/AAC
From €79.99
100W x2
RCA/Bluetooth
Passive Speakers
Bluetooth Codecs
≤ 0.5%
≥98dB
TPA3116 x2
24V/4.5A
From €239.99
Bluetooth 2.1 Ch Amp
RCA1/RCA2/Bluetooth
Speaker Out/Sub Out
Bluetooth Codecs
SBC/AAC/aptX/aptX HD/aptX Adaptive/aptX Lossless/LDAC
≤0.003%
≥112dB
TPA3255/Qualcomm QCC3095
48V/5A,48V/10A
As Seen On
