12V Trigger Sync Interface
Logarithmic Potentiometer
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
From €109.99
ZA3 Balanced Stereo Amplifier
2.0 CH Amp
RCA, XLR, ¼”TRS
Passive SPK +Sub-out
<0.006%
≥106dB
From €119.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From €89.99
From €79.99
TB10D Stereo Audio Amplifier
2.0 Ch Amp
300W x2
Passive Speakers
≤ 0.3%
≥ 90dB
From €79.99
2.0 Ch Amp
Passive Speakers, Pre-Out
Stereo Mode
XLR Input
Subwoofer Channel
  • 5 stars: 4 (100%)
  • 4 stars: 0 (0%)
Phdejo
Ordered the ZD3 and ZA3+48V/5A PSU (no Op-Amp rolling), dug up my Monitor Audio Studio 10’s from good 30 years ago, added Fosi’s XLR cables (30 cm) and GEARit Premium Braided Speaker Wire (4.57 m, 2 x 2.5 mm2/14AWG, black), connected my iPhone 16 via Bluetooth and already enjoyed the results. These things are tiny, fit easily on top of one of my speakers and are a beauty to behold. Monitor Audio was the first British speaker company to offer metal-dome tweeters (aluminium/magnesium and gold-color anodized finish). The woofer uses an aluminium-alloy cone. It all sounds neutral, has a smooth treble, excellent soundstage depth, and a good feeling of low-frequency authority. In my living room of about 16 m2 there is nothing to be ashamed about. My first digital setup. I’m a happy camper.
Zdenek Skoda
I have been a Fosi Audio fan for a couple of years, and their gear is in my daily listening. My first piece was the ZA3, bought at launch, and it was my first real step into Hi-Fi. Since then I have built up to the full Fosi stack, ZD3 into ZP3 into ZA3, all running Oracle II op-amps, paired with my own 3D printed speakers. My passion is drum and bass, so that is how I judge everything. This setup delivers raw, deep, clean bass into the low 30 Hz range with no subwoofer, and it still makes me want to dance every time. It is remarkable what sound is possible at these prices, and it is exactly why I keep coming back to Fosi, quirks and all.
ZA3 (amp)
A great little amp with excellent sound and solid build, and a playful streak, because it comes apart so easily for OPA rolling. Simple to use, outstanding value, and in my opinion the perfect first step into Hi-Fi.
Plus
- Astonishing sound and build quality for the price
- Easy OPA rolling
- Stereo and mono versatility, strong power output
- 12 V trigger
- Great customer support
Minus
- Early units ran hot (resolved on my newer unit, and my first one died from it but was replaced under warranty)
- The Oracle II op-amps are not fully happy in the ZA3. They give occasional artifacts and cracking and eventually die, so their reliable lifespan here is short if you listen a lot
Anonymous
Výborný zesilovač, který předčil mé očekávání. Zvuk zní skvěle, poslechově baví. Velká výhoda je jeho velikost, kdy je možné ho bez problému umístit i za televizi. Zesilovač nahradil můj Hifi zesilovač který váží 18 kg. V kombinaci s DACem od firmy Fosi se pro mě stala tato sestava více než uspokojivá.
Faustino Sevilha
Good amplifier I go use in mono mode to drive a subwoofer. I have another ZA3 and a ZD3.
