Knobs designed for subwoofer
Pre-Out Connector
  • 2.1 Channel Amplifier: The BT30D PRO integrated amplifier features two sets of passive speaker outputs and one set of passive subwoofer outputs, making it easy to set up a 2.1 home theater or other stereo HiFi audio systems.
  • Exquisite Craftsmanship: This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well-designed case, along with the high-quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
  • If you plan to use a 48V power supply, active cooling (such as a fan) is required to ensure stable operation.
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From €109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
From €89.99
From €89.99
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
  • 5 stars: 119 (83%)
  • 4 stars: 24 (17%)
Christopher Davies - The HiFi Heretic
BT30D Pro: the perfect 2.1 Desktop HiFi Solution!
This is my third BT30D Pro. It is a fantastically versatile unit with a crazy amount of power when used with a 48V GaN PSU. This one was used to create a genuinely portable 2.1 system, with a carry handle and speaker-retaining cargo clamps, and an Oilsky M308 DAP.
There are only two improvements needed to this amplifier (and the lesser non-Pro model) -- the addition of a High-Pass Filter with 80Hz and 100Hz switching options.
The second upgrade is a three-way power switch: OFF, RCA, and BT.
If you are looking for Most Bang For The Buck, then the buck stops right here! Buy with confidence - you won't ever regret your purchase.
Miguel Castellanos
EXCELENTE!!
Vale mucho la pena este amplificador!!. Es compacto, el sonido es limpio, potente y tiene un buen control de volumen. Pude revivir unos viejos altavoces Technics SB F66A que funcionan excelentes, y hasta le siento mejores bajos que los que recordaba.
Solo recalco el detalle que se calienta un poco con la fuente 48V 5A. Le coloque un peque?o ventilador y va bien. Pienso colocar un subwoofer pasivo en un futuro.
Mehnas Nazar
Good product
I am thoroughly impressed by the build quality and the power output of this compact amplifier. It drives both my passive speakers and subwoofer effortlessly, delivering crisp highs and punchy lows. The Bluetooth connection is stable, and having precise control over the sub-bass frequency is a massive bonus for audio enthusiasts."
Samuel Ruiz
This is nice!
Wow, I love this amp already! I built my own 8” subwoofer, and this powers it perfectly. It looks super clean in my setup and doesn’t take up very much space. I will definitely be purchasing more products from Fosi in the future!
Eric Rystedt
Soundboard extreme
Replace a 3216 chip amp with this amazing amp. What a difference. Powers 6 drivers plus 1 sub. Thanks fosi audio.
Darko
My entrance to the Fosi world
I originally bought the BT30D Pro for a secondary 2.1 setup, but it slowly became one of the most useful pieces of gear in my entire system.
The subwoofer integration and control flexibility are excellent. In my current 5.1 setup I use it for center/LFE duties and it made balancing the relationship between center channel vocals and multiple subwoofers much easier than with traditional stereo amps.
What surprised me most is how effortless and dynamic it sounds. It has plenty of power, very good bass control and never feels strained, even during long listening sessions at higher volumes.
The pre-out functionality makes it extremely versatile. I ended up using it not just as an amp, but also as a control hub for different amplifier and subwoofer combinations.
For the price, the value is honestly ridiculous.
Ali
A nice and compact amplifier.
I use Cambridge Audio SX 50 speakers with SMSL 200 pro DAC with Macbook Air m4 as a streaming device. The size and audio quality of this Amp is perfect for my desktop setup.
Jeff W.
Simple and perfect for my patio speakers
I use this amp to power my outdoor speakers mounted in my backyard near the pool. My source is an old Chromecast Audio or Bluetooth. The set up is so simple and just what I needed. It breathed new life into my old speakers and my backyard never sounded better.
Jesse H.
BT30D Pro (48v)
This amplifier is powerful and can drive my speakers and subs well. I am impressed by the amount of tone control. My speakers never sounded better. I purchased another BT30D Pro (48v) to use in my other listening space.
Boloban
All that you ever wanted
If you always an amplifier that can power a subwoofer at this price range and as a bonus you can get a stereo amplifier all in one.
You can bring back to life you old car sound or drive a new pair of speakers you better prepare for a beautiful sound what ever your set is
Michel K.
Very good amplifier, great sound
Use this with KEF speakers, very clear sound. Lots of power with the 48v power supply. Didn't think this much power would come in such a small package. I definitely recommend Fosi!
Jonathan Williams
Very clear clean sound plenty powerful... BUT...
Using them with two Klipsch References bookshelf speakers and they sound amazing. However I am also using an 8" 4ohm passive sub and the sub and the sub range never is able to meet the bookshelf speakers. It can push the sub enough but by the time you hear it the bookshelf speakers are drowning it out. You need to be able to turn the two channels down or you have to use a powered sub. If there is a different option you make that can address this or has a more powerful mono channel let me know and I will upgrade.
Also the form factor and fit are perfect for me. Nice quality stuff.
Roderick Bridges
45 volt 5 amp Hot in many different ways!!!!
Great little device has lots of power, using the sub out to run a buttkicker, the output rating is more like a hundred Watts each on the two channels and 200 Watts on the sub output. If using in Bluetooth mode connected to a TV there is a delay, so the mouth movement doesn't match the sound but for all other Bluetooth audio excellent quality even though there is a slight reduction in volume compared to using the RCA's. Device just get hot and could use some sort of fan or external heat sink even though it's using the aluminum chassis. Occasionally if gets too hot sound kind of just goes away. But but just flip the on and off switch off and on and back up and running maybe just turn it down a hair. Also for your information the main volume controls both audio output after you adjust the sub to your liking level. Also the Bluetooth volume is adjustable say on your source but you will have to set the amp volume to wherever it sounds the best when at max volume on Bluetooth. That's because the volume on the amp dial does not move mechanically.
G��bor
Allmost perfect
In a 5m x 6m x 3-5(hight)m with a pair of 8 Ohm 65 cm x 32cm x 26cm speakers, on ~66-70% of wolume, it can do a good job. I do not feel weak, even wothout subwoopher, i can adjust the base till it is in balance. I feel the highs amd the mids are great, they have good detaile and are banaced, and again, can be adjusted tu have more/less.. so i am pleased. With subwoopher, the bass is very pleasing, if you place it to a right spot. Very nice to add a bass fequency potmeter??
Downside is, the OPamps areen't upgradebla, despite the previous BT20 Pro have such a feature. It is "sad but true"
Ui:on bluetooth, if the soud is much more silent then on wired connection, try not a phone but a Bluetooth Player/dac insteed, then i needed only 55-66% to turn that players volume up. For get the same result, my phones vlolume setting nedeed over 70-90%
Mukesh Arjuna
Fosi Audio BT30D Pro 2.1
Recently I brought Fosi 30D Pro , Its was Nice and amazing sound quality i love the sound clarity of Fosi Audio , There is no words such a Good Stuff for Music lovers
George
Great Product with Cheap price
I would suggest to by this amazing product, great sound amazing performances
George
Amazing Product
My little boy is amazing performances, 100% worth
