**Engineering Evaluation Report** **Component:** Fosi Audio C3 Gaming External Sound Card for PC, USB DAC/AMP with 7.1 Surround & Footstep Enhancement, Audio Equalizer & Desktop Volume Control, Headphone Interface for PS5 Switch FPS **Application:** External USB DAC/AMP sound card optimized for gaming and multimedia use. The device delivers high-fidelity audio with virtual 7.1 surround sound, footstep enhancement for competitive FPS games, a customizable audio equalizer, and convenient desktop volume control. It supports PC, PS5, Nintendo Switch, and other platforms via USB connection, providing improved soundstage, clarity, and immersion for headphones and external speakers in gaming, music, and entertainment setups. **Objective** The objective of this evaluation was to assess audio fidelity and 7.1 surround performance, footstep enhancement effectiveness, equalizer and volume control usability, USB connectivity and compatibility with PC/PS5/Switch, build quality and heat management, and overall durability under extended gaming sessions. **Methodology** 2.1 Mechanical & Audio Inspection - Verified DAC/AMP specifications, virtual 7.1 surround processing, footstep enhancement algorithm, and equalizer bands. - Evaluated housing construction, knob/knob quality, USB interface, and headphone output impedance matching. - Inspected LED indicators and overall build finish. 2.2 Installation & Compatibility Testing - Connected the device to PC, PS5, and Nintendo Switch systems. - Tested driver installation (if required), plug-and-play functionality, and compatibility with popular gaming headsets. - Evaluated desktop volume control response and software integration. 2.3 Performance Testing - Conducted listening tests in FPS games for footstep clarity, spatial awareness, and 7.1 surround imaging. - Measured audio output quality, equalizer customization impact, and latency. - Evaluated performance with music and multimedia content for overall fidelity. 2.4 Durability Assessment - Performed extended continuous operation and repeated connection cycles. - Tested under typical gaming desk conditions including vibration and temperature variation. - Inspected for connector wear, audio degradation, and housing integrity. **Results** **3.1 Audio & Processing Performance** - Clear, detailed sound with effective virtual 7.1 surround and enhanced footstep detection in FPS titles. - Customizable equalizer provided meaningful adjustments across frequency bands. - Strong headphone amplification with good power output and low noise floor. **3.2 Installation & Usability** - True plug-and-play compatibility across PC, PS5, and Switch with minimal setup. - Responsive desktop volume control and intuitive interface for quick adjustments. - Compact design fit easily on gaming desks without occupying excessive space. **3.3 Performance** - Noticeable improvement in positional audio and immersion compared to onboard sound. - Low latency suitable for competitive gaming. - Balanced output worked well with a wide range of gaming headsets and speakers. **3.4 Durability** - Solid construction withstood extended use and minor desk impacts. - USB connection and controls remained reliable after repeated cycles. - Projected service life of 3?C5+ years with normal gaming use. **Discussion** The Fosi Audio C3 Gaming External Sound Card is a capable and affordable upgrade for gamers seeking better audio performance without investing in high-end internal sound cards. The combination of virtual 7.1 surround, footstep enhancement, and a flexible equalizer significantly improves situational awareness in competitive FPS games while enhancing overall listening enjoyment. Its compact size and easy USB connectivity make it highly practical for multi-platform use (PC, PS5, Switch). The desktop volume control adds convenient real-time adjustments during gameplay. This device strikes a good balance between features, performance, and value for both casual and competitive gamers. **Potential Considerations** - Virtual surround performance depends on headphone quality and game audio implementation. - For advanced customization, pair with companion software if available. - Position the unit away from strong magnetic fields or excessive heat sources. - Ensure USB port provides stable power for optimal amplifier performance. **Conclusion** The Fosi Audio C3 Gaming External Sound Card for PC, USB DAC/AMP with 7.1 Surround & Footstep Enhancement, Audio Equalizer & Desktop Volume Control, Headphone Interface for PS5 Switch FPS provides clear audio performance, effective gaming features, easy multi-platform compatibility, and solid build quality. It meets electrical, audio, usability, and durability requirements, making it a reliable external sound solution. The footstep enhancement and customizable equalizer deliver tangible benefits for immersive and competitive gaming. A well-designed, compact, and value-oriented audio upgrade. Highly recommended.
