Fosi Audio IM4 Offener In-Ear Monitor
Overview Specs FAQs
IM3
€69.99
 No Battery. No Bluetooth. Just Plug In.
Always-on wired connection for stable, low-latency listening.3.5mm Input · USB-C DAC Included
Fosi Audio EU
 One Cable. Everything You Do.
Built for gaming, music, meetings, learning and monitoring.
Fosi Audio EU
Fosi Audio EU
 HIGH-RES SOUND. TRUE TO DETAIL.
Low Distortion · Clear Highs · Full-Bodied Lows
Fosi Audio EU
Fosi Audio EU
Fosi Audio EU
 Comfort Comes Naturally
Lightweight Design · Resin Material · Skin-Friendly Fit
Fosi Audio EUFosi Audio EU
Product Specification
Shell Material 3D-Printed Resin Front Chamber + CNC-Machined Aluminum Alloy Rear Cover
Driver Unit 10mm N52 Dual-Magnet Dual-Cavity Dynamic Driver
Diaphragm Aluminum-Magnesium Alloy Diaphragm
Frequency Response 20Hz - 20kHz
Impedance 32Ω
Sensitivity 107dB
Cable 5N Oxygen-Free Copper Cable
Connector 2-pin 0.78 mm (Detachable)
Audio Jack  3.5mm Gold-Plated Plug
USB-C DAC Included (Sampling Rate: 384kHz/32bit, ADC: 48kHz/24bit)
Weight (per earbud) 4.3g ± 0.5g
Weight (incl. cable) 29.8g ± 1g
  What's in the Box?
①IM3 Earphones
②Detachable+Mic Cable With Inline Controls
③USB-C-AUF-3.5MM-Kabel
④Balanced Ear Tips
⑤Bass Ear Tips
⑥Earphone Pouch
⑦User Manual&Quick Guide
What are the benefits of an open-back design, and how does the IM3 work?
The open-back design helps create a more spacious, natural listening experience, making music feel less confined. Its wired connection provides direct audio playback without requiring Bluetooth pairing or charging the earbuds.
Are the Fosi Audio IM3 earbuds good for gaming?
Yes. The Fosi Audio IM3 is suitable for gaming on compatible devices, offering a wired listening experience for a wide range of games, from immersive single-player adventures to fast-paced multiplayer matches.
What devices are compatible with the Fosi Audio IM3?
The Fosi Audio IM3 is compatible with PCs, laptops, smartphones, and other devices with a 3.5mm headphone jack. For compatible devices without a 3.5mm headphone jack, the included USB-C adapter provides a convenient connection option.
Does the IM3 have a microphone?
Yes, the IM3 features an inline microphone with a physical mute switch, making it ideal for gaming, calls, and online meetings.
Do I need to charge the IM3 earbuds?
No. The IM3 is a wired in-ear monitor that does not require charging. Simply plug it into your device and enjoy zero-latency audio.
What is the weight of the IM3?
Each earbud weighs approximately 4.3g (±0.5g), and the total weight, including the cable, is 29.8g (±1g), making it extremely lightweight for all-day comfort.
Are the cables detachable?
Yes, the IM3 uses a 2-pin 0.78 mm detachable cable design, allowing you to replace or upgrade the cable as needed.
 Does the IM3 support a USB-C connection?
Yes, the IM3 includes a USB-C to 3.5mm DAC adapter with 384kHz/32bit sampling rate and 48kHz/24bit ADC, providing high-resolution audio for USB-C devices.
