S3 Lite Streamer
Bring Your Old Stereo into the Modern Age
Pure Digital Transport with USB Output
A Perfect Digital Bridge to Your External DAC
The S3 Lite brings modern streaming to both classic and modern HiFi systems, offering a simple, stable connection and high-fidelity digital audio that complements your existing hardware. Enjoy seamless playback with no audible pops, and relay noise when changing tracks and switching streaming quality.
You can stream music directly from your music Apps to the S3 Lite for seamless playback.  Capable of up to PCM 32bit/768kHz lossless audio, it delivers wired-grade sound quality with the convenience of wireless control.
Unlock Up to 768kHz Lossless Audio
Its built-in USB-A output supports lossless audio up to PCM 32bit/768 kHz, delivering a detailed, transparent signal that allows your downstream DAC and amplifier to define the system’s final character.
Seamlessly Integrates into Your Existing Stereo System
Comprehensive Digital Outputs
USB-A, optical, and coaxial outputs ensure excellent synergy with virtually any DAC. With digital-output THD+N as low as 0.000003%, the S3 Lite delivers a clean, faithful audio source.
Stream Your Favorites
All-New App Super Easy Setup
The S3 Lite is easy to set up and control through the Fosi Audio app. The app’s clean, intuitive interface allows you to manage playback, switch sources and output modes, and fine-tune your sound with a built-in 10-band precision EQ.
Seamless Wireless Streaming
Dual-band 2.4 GHz/5 GHz Wi-Fi 6 delivers stable coverage of up to 100 meters, making setup smooth and quick while enabling seamless control across rooms.
Play Music Everywhere
The S3 Lite supports multi-room synchronized playback via Google Cast and AirPlay 2. With multiple S3 Lite or S3 units placed in different rooms, you can easily control them from your phone and have all speakers play the same music simultaneously, letting your music follow you wherever you go
Compact Footprint
The S3 Lite takes up minimal space and fits effortlessly on a desk, shelf, or inside your HiFi rack. Its clean, minimalist design blends naturally into any audio setup.
Power Sync
The 12V Trigger enables synchronized power on/off with a downstream DAC, automating system control for seamless operation.
Bluetooth Remote Control
Enjoy effortless control of input selection, playback, and power from up to 15 meters away —all without leaving your seat.
Panel Overview
Pure Digital Transport & HiFi Audio Streamer
Dedicated Digital Bridge for External DACs
The Fosi Audio S3 Lite is designed as a pure digital transport to stream pristine, uncompressed audio directly to your high-end external DAC. Featuring USB, Optical, and Coaxial outputs, this HiFi music audio streamer delivers a clean digital signal to your home stereo setup with zero added noise or signal degradation.
Next-Gen Wireless Streaming: Dual-Band Wi-Fi 6 & Bluetooth 5.3
Ultra-Stable, Lag-Free Wireless Connectivity
Upgrade your sound system with high-speed dual-band 2.4GHz/5GHz Wi-Fi 6 and Bluetooth 5.3 connectivity. Experience uninterrupted, high-resolution wireless streaming across your home network whether playing local audio files or online music platforms.
Ultra-High Resolution Audio Transmit (Up to PCM 768kHz)
Precision engineered for audiophiles, the USB output supports lossless PCM audio up to 768kHz with an ultra-low harmonic distortion rate of THD+N ≤0.000003%.
Enjoy hyper-detailed sound quality, remarkable dynamic range, and ultra-transparent acoustic clarity.
Seamless Ecosystem: AirPlay 2, Google Cast, Spotify & TIDAL Connect
Multi-Room Audio & Universal Streaming Support
Stream directly from your favorite platforms with full native support for AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect, Roon Ready, DLNA, and Qobuz. Effortlessly integrate the S3 Lite into your smart home network and control multi-room playback directly from your smartphone or PC.
Advanced Sound Personalization: 10-Band Custom EQ
Tailor Your Sound to Fit Any Room or Speakers
Take full control of your listening experience using the integrated 10-band EQ parameter controls. Precisely tune frequency responses to match your room acoustics, headphones, or power amplifier for customized sound signatures.
Compact Design & Smart Control
Compact 5.79-inch (147 mm) chassis fits easily on a desk, shelf, or HiFi rack. Bluetooth remote control works up to 15 m. The built-in 12V Trigger synchronizes power with your external DAC.
  • S3 Lite
  • DC Power Adapter
  • Optical Cable
  • Bluetooth Remote
Can the S3 Lite play audio by itself?
No. It is a pure‑digital transport and requires an external DAC. Removing the onboard DAC brings lower costs and cleaner digital‑signal output.
What protocols are supported?
8 major mainstream protocols: Google Cast, AirPlay 2, DLNA, Spotify Connect, Roon Ready, TIDAL Connect, Qobuz Connect and Bluetooth.
How can I pair it with other Fosi products?
It features the unified matte‑black family‑style design. Connect it to a DAC (such as the ZD3) via USB, optical or coaxial cable.
What is the 12V Trigger for?
The 3.5 mm jack outputs a 12 V trigger signal to power‑cycle your DAC or amplifier in sync with this unit.
  • 5 stars: 15 (79%)
  • 4 stars: 3 (16%)
  • 2 stars: 1 (5%)
Jonas Linde
Clear sound, solid build
Justin
It just works
Works perfectly well paired with my fosi DAC. Might be a little more pricey compared to others but I love the theme I have going here.
Stéphane Théus
Having already owned the Fosi Audio S3 streamer—whose qualities I greatly appreciated—I didn't hesitate to buy the "Lite" version for a second setup that already includes a DAC for the S3 Lite to pair with.
Setting up the Fosi Audio S3 Lite was incredibly easy, especially since I already had the dedicated app on my smartphone. It is worth noting that the app has improved since the S3 was first introduced; it is very user-friendly and offers numerous, effective features. I simply opened the app and selected the "Device" icon. Once that tab was open, I tapped the "+" sign to the right of "Device," which triggered a search for new hardware. The S3 Lite (switched to ON, with the white indicator light flashing) appeared quickly. From there, I just had to complete the setup process by following the on-screen instructions. After the app automatically checked for and installed the latest firmware, I was ready to enjoy the new setup.
The Fosi Audio S3 Lite is compact, well-built, and delivers a stable, high-quality audio stream to the Fosi Audio ZD3 DAC (equipped with Sparkos SS3602 OpAmps) with which it is paired. The result is thrilling. The value for money offered by this setup should easily win over most audiophiles, given the stunning quality, functionality, and sonic performance achieved by combining these Fosi products. The listening experience is truly moving—and ultimately, that is all one could ask for.
Finally—and this is very important—the customer service is attentive and impeccable. I was also pleased to see the brand's new European website, where the Euro has (finally!) replaced US Dollar billing (eu.fosiaudio.com).
Once again, well done Fosi!
Nosferatrom
Simple, Clean and Excellent
I've been very impressed with the Fosi Audio S3 Lite. It is a simple but highly capable digital streamer, especially if you already own a quality external DAC. Streaming is stable, the digital output is clean, and having USB, optical and coaxial outputs makes it extremely versatile.
The compact design and wide streaming support are also big pluses. For the price, the S3 Lite is one of the easiest ways to add modern streaming capabilities to an existing Hi-Fi system without compromising the digital signal.
Krzysztof Łopusiewicz
działa tak jak się tego spodziewałem ! testowałem tylko TIDAL bo to użytkuję,wszystko OK !
Frans Christensen
A fantastic little device.
Sound quality far above its price.
Easy to setup and use.
Very satisfied with this fantastic little product.
Can only recommend it.
With a high end power supply you get a highend S3 streamer
Micael Svedlund
Seems to work fine, sound quality is good using Apple Music Lossless and connecting to Fosi DAC via optical fiber (TOSLINK).
I had some problems pairing the remote control, but it didn’t matter much since I can control the Streamer with the Fosi-app.
NIKOLAY Chaushev
Very good sound. Better then my computer. Thank you Fosi !
Chris C.
A Focused Network Transport That Knows Its Place
What I find most appealing about the S3 Lite is that it knows exactly what it is trying to be. Instead of attempting to replace every component in a system, it focuses on being a dedicated network transport for listeners who already have a DAC they prefer. That approach makes a lot of sense to me, and I appreciate the restraint. Its understated design, absence of a front display, and emphasis on digital connectivity give it a very purpose-driven feel that should work well in a variety of enthusiast setups. In everyday use, playback remained dependable through extended listening sessions, the various sample rates I tested were handled properly, and I had no major reliability concerns.
Of course, that focused approach also creates some limitations. Because there are no analog inputs, the Lite isn’t really positioned to act as the hub for other sources, such as a turntable or CD transport. I can understand leaving HDMI off a product aimed primarily at music playback, although I would have liked to see more flexibility when it comes to subwoofer integration and bass management. The companion app is another area where there is room for improvement. Navigation can feel slow, and some of the interface appears to include functions that aren’t particularly applicable to the Lite. I also encountered streaming interruptions somewhat more often than I did with the full-size S3. Gapless playback worked, but it wasn’t consistently as smooth as I would have hoped.
Overall, the S3 Lite makes the most sense for someone who already has a DAC they like and wants a straightforward network transport rather than another all-in-one component. Its focused design is one of its strengths, although buyers should be aware of the limitations that come with that specialization.
Customer Review
Fantastic, but Niche
The Fosi S3 Lite is clearly aimed at audiophiles who want to add modern streaming to an existing DAC or audio system, and it offers an impressive amount of connectivity for such a compact device. AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect, Wi-Fi 6, LAN, and high-resolution digital output cover just about every streaming scenario I can think of.That said, I think it's a fairly niche product. If you already have an Apple TV, Apple Music subscription, and a full AVR-based home theater setup, much of what the S3 Lite provides becomes redundant.Where this makes considerably more sense is on a desktop or in an office audio setup. Pair it with a DAC and a set of studio monitors or powered speakers and you can add convenient network streaming without replacing the rest of your equipment.It's also a good way to modernize an older HiFi system while continuing to use the DAC, amplifier, or speakers you already like. Just keep in mind that there's no built-in DAC, so this is specifically a digital streaming transport rather than an all-in-one streamer.Overall, it's a very capable little device for the right setup. I wouldn't add one to my AVR system, but as a way to piggyback high-quality streaming onto a dedicated office or desktop audio system, it makes a lot more sense.
Stefano
Fosi Audio S3 Lite: uno streamer puro, pensato per chi possiede già un buon DAC
Il Fosi Audio S3 Lite è un prodotto che va capito per quello che è, senza sovrapporgli aspettative sbagliate. Non nasce per sostituire un amplificatore, non prova a diventare un preamplificatore universale e soprattutto non integra un DAC.È un trasporto digitale di rete: riceve la musica dalla rete domestica o dai servizi di streaming e la invia, senza conversione analogica interna, a un DAC esterno oppure a un amplificatore che ne possieda già uno valido.Questa scelta è precisa e, secondo me, molto intelligente. In tanti impianti moderni esiste già una buona sezione di conversione: può trovarsi in un Denon, in un DAC dedicato, in un amplificatore integrato o in diffusori attivi ben progettati.Inserire un secondo DAC nello streamer rischierebbe soltanto di far pagare una funzione inutile o di creare dubbi su quale percorso usare. Fosi, con l’S3 Lite, ha scelto invece di concentrarsi sulla sorgente digitale. È un apparecchio dedicato a far arrivare la musica nel modo più ordinato possibile al componente che dovrà occuparsi del resto.Nel mio caso è collegato digitalmente al Denon, che mantiene il ruolo di convertitore e centro della catena. Il collegamento è immediato: lo streamer entra nella rete, il Denon riceve il segnale digitale e l’impianto resta pulito, senza dispositivi superflui o collegamenti strani. È una configurazione semplice, ma non banale. Quando ogni componente svolge una funzione precisa, l’intero sistema diventa più facile da capire, più pratico da usare e anche più aperto a eventuali miglioramenti futuri.La parola Lite potrebbe far immaginare un prodotto ridotto all��osso. In realt�� �� ridotto soltanto nelle funzioni che Fosi ha scelto consapevolmente di eliminare. Dal lato della connettivit�� �� tutt��altro che povero. Sul retro sono presenti uscita Audio-USB, ottica e coassiale. Questo permette di collegarlo praticamente a qualunque DAC esterno o apparecchio dotato di ingressi idonei. La USB �� particolarmente interessante per chi possiede un convertitore recente, mentre ottica e coassiale restano soluzioni solide, diffuse e immediate per inserirlo in un impianto gi�� esistente.C���� poi la porta Ethernet per chi vuole una connessione cablata, soluzione che in un sistema fisso trovo sempre sensata, e c���� il Wi-Fi 6 dual band per chi preferisce maggiore libert�� di posizionamento. La presenza del Wi-Fi moderno rende il prodotto molto pi�� flessibile: non obbliga a tenere lo streamer vicino al router, non richiede adattatori aggiuntivi e permette di sistemarlo dove ha pi�� senso dal punto di vista dell��impianto.Il Bluetooth 5.3 �� una �� secondario ma utile. Non �� il motivo per cui comprerei un prodotto di questo tipo, visto che l��obiettivo principale �� lo streaming di qualit�� tramite rete, per�� torna comodo per gli ascolti rapidi o per chi vuole inviare qualcosa dallo smartphone senza aprire altri servizi. La vera forza dell��S3 Lite resta comunque il lavoro in rete.La compatibilit�� con Spotify Connect, TIDAL Connect, Qobuz Connect, AirPlay 2, Google Cast e DLNA lo rende praticamente universale. Non costringe a usare una piattaforma proprietaria specifica e questo �� un vantaggio concreto. Si pu�� scegliere il servizio che gi�� si utilizza, selezionare lo streamer come dispositivo di riproduzione e lasciare che sia lui a occuparsi del flusso musicale.L��app Fosi �� un altro punto che ho apprezzato. Ha un��impostazione essenziale, non vuole trasformarsi in un ecosistema enorme e non nasconde le funzioni utili dietro menu complessi. Serve per configurare il dispositivo, gestire le connessioni disponibili e usare le principali opzioni. Per uno streamer puro �� l��approccio corretto. Non servono animazioni inutili, schermate piene di icone o decine di impostazioni che si usano una volta sola. L��app deve essere rapida, chiara e affidabile: ed �� esattamente cos��.C���� anche un equalizzatore digitale a dieci bande. �� una funzione da usare con criterio, ma ha senso averla. In una stanza difficile, con diffusori che hanno una risposta particolare o con una postazione vicina a pareti e mobili, una piccola correzione pu�� essere utile. Personalmente preferisco partire sempre da un��impostazione neutra e lavorare prima sul posizionamento dei diffusori, per�� trovo positivo che Fosi lasci questa possibilit�� a disposizione senza obbligare l��utente a inserire un ulteriore componente nella catena.Anche il trigger da 12 Volt merita di essere citato. Non cambia il suono, ovviamente, ma pu�� cambiare la comodit�� di utilizzo. Se l��amplificatore o il DAC supportano il trigger, l��accensione dello streamer pu�� sincronizzare l��avvio del resto dell��impianto. �� un dettaglio che solitamente si incontra su componenti pi�� costosi o pensati per sistemi articolati. Dimostra che, pur essendo compatto e orientato alla semplicit��, l��S3 Lite �� stato progettato tenendo presente anche chi desidera costruire una catena ordinata e ben integrata.Il telecomando Bluetooth segue l...
TZ
Simple, Clean Way to Add Modern Streaming to an Existing Stereo
I have had a dedicated stereo setup in my living room for years, but getting clean streaming music to it without hooking up a laptop or running long cables was always a bit of a nuisance. I already had a sound converter and amplifier that I really liked, so I did not need an expensive, all-in-one box with parts I would never use. The S3 Lite caught my eye because it is built strictly as a digital transport��it handles the wireless streaming and feeds a direct digital signal straight into your existing equipment.Setting it up on my home network was very straightforward. The box itself is compact, lightweight, and finished in a solid matte-black metal casing that sits neatly on the shelf next to my other gear without taking up much room. The kit comes with everything you need to get going, including the power adapter, an optical cable, and a handy Bluetooth remote control that works from across the room without needing a direct line of sight.In daily use, the connection has been rock solid. I tested it extensively with Spotify and Tidal, streaming tracks directly from both my iPhone 17 Air and my Samsung Fold 8 Ultra. Switching between Apple AirPlay and Google Cast worked without any hiccups or annoying buffering delays.The back panel offers USB, optical, and coaxial digital outputs, giving you plenty of flexibility to hook it up to whatever converter or digital receiver you already own. It even has a 12-volt trigger jack, which is great for turning on connected equipment automatically when the streamer wakes up.The only real thing to keep in mind is that this unit has no standard red-and-white analog audio plugs or headphone jacks on the back, so you must connect it to an external digital-to-analog converter or an amp with digital inputs. The buttons on the remote are also on the smaller side, but once you get used to the layout, it is easy enough to operate. For around two hundred dollars, it is a well-built, hassle-free little streamer that brought my older stereo gear right into the modern streaming era.
PS
nice inexpensive alternative
i have tons of speakers, subs and amps ranging from sonos to kef to wiim. sonos is expensive. wiim is cool but they dont have airplay in everything. kef is great but the bluetooth lags and gives lip sync issues. i previously bought the fosi za3 as a headless amp to see how it would perform with some bookshelf speakers i had and i had never had fosi before. for the money, that amp was fantastic but it ended up being a little too bright for my taste.so this thing. i have a exercise bike that uses bluetooth and my sonos amp doesnt have that feature. to combat that, i put this streamer on top and had the bike connect to it via bluetooth, then used an optical to HDMI adapter to have it talk to the sonos amp. everything worked excellent.with that experience, here's what i'll say the good was:- easy setup with no user ID required- the interface of the app is very clean and intuitive to use- spotify connect and airplay worked with zero issuesthe not as good:- i hooked up bluetooth to my desktop and played a video through it. there was audio lag and also lots of popping in the transmission. the fosi was maybe 6 inches from my pc.- when i tried to play music from my phone via bluetooth to the fosi, it was connected to it via bluetooth but started playing from the phone speaker. not sure why it didnt just play directly to the fosi.- there is no input sensing. i had the device on USB output but had the fosi output via optical to my sonos. when trying to play a song when it was on USB, the device did not switch and i had to do it manuallyi think all in all for 1/3 price of the competition, this will totally do the job. i'll keep it for my application.
Bad Photo 99
Works Great!
I purchased directly from Fosi and shipped from China, and delivered today at my home in USA. It took 8 days from the day I ordered to delivery. I downloaded the Fosi App on my Iphone 17, made the wifi connection from my phone to the S3 Lite, connected the S3 Lite to my Fosi ZD 3 DAC using the USB connections on both, and then output to my Sony Receiver. I listened to Tidal Connect and sound was fantastic. No issues with the Fosi App or the install process, including the connection to my local wifi network. Highly recommend!
S. Edwards
Excellent performance in a unique digital streamer; questionable default settings are fixable
The Fosi S3 Lite is a digital streaming source. It is essentially the digital streaming section of the Fosi S3 non-Lite, without the analog section nor the input connections - this Fosi S3 Lite is digital output only. As such, the use case for this is someone who already has an audio system with a DAC (digital to analog converter), or an older digital receiver that is lacking streaming capabilities.If that is what you need, this is a clean way of adding such capabilities and is unique at this price point. The digital processing uses current state of the art chipsets (Amlogic A113x) and includes every major type of digital output connection: optical, coaxial, or USB (for USB DACs, not PCs). It can drive optical and coaxial at the same time which might make for some interesting flexibility with the ability to drive two DACs. However, USB output works only by itself.The list of capabilities will accommodate the majority of sources, some more natively than others, but every major service is represented or compatible in some way. The usual connection protocols are present such as Chromecast, Airplay 2 (a leg up on competitors still stuck on Airplay 1), and UPnP/DLNA. Users of Amazon Music, YouTube music, and Apple Music will have to use Chromecast or Airplay from within their respective apps. It appears that Fosi is slowly adding native support for more services, and currently includes Roon Ready, Tidal, Spotify, and Qobuz, all indicative of Fosi's intent to demonstrate their commitment to hi-fi enthusiasts. If that weren't enough, the S3 Lite also plays DSD files (and converts them to 192kHz PCM signals) which is a format that only die-hard audiophiles remember and care about - this capability is not advertised, but I can confirm that I was able to play several DSD/DSF files, further testament to Fosi's intent to appeal to audio geeks. PCM sources up to 192kHz sampling rate and 24 bit resolution also played fine.I tested using the coaxial and also the optical output to a receiver. I tried several methods to play music on the Fosi S3 Lite: the native Fosi app, BubbleUPnP app from a local DLNA server, and casting music from inside the Amazon Music app and YouTube music app using Chromecast. Everything worked as expected and was stable while streaming over a wired ethernet connection. It should be noted that everything is controlled by an app in some way as there is no display on the device and the few buttons on the front panel are confusing enough with their multiple functions (press, hold, double tap) that I never used them.Bluetooth from a phone works. Any audiophile will want to use an ethernet connection for best audio quality, but Bluetooth works for cases such as a guest wanting to share music.The unit includes some capabilities that are unnecessary in a digital source device and I would have preferred these to be deleted or at least defaulted to a neutral state. The first is a 10 band graphic EQ in the Fosi app which works well enough, although the boost/cut range is rather low (I estimate 3-5dB). The second is volume control which is equally pointless in a device like this since users of such a digital source are likely to prefer downstream components for EQ and volume control. More egregious is that the EQ is defaulted to a curve (consisting of boosted bass and treble) and the volume control is defaulted to 60%. It's a problem easily corrected in the Fosi app, but imagine if a Blu-ray player were delivered with an EQ active and attenuated volume! As a matter of principle, enthusiasts seek to preserve resolution and accuracy with source devices and the S3 Lite compromises both out of the box since the output is purely digital (attenuating volume digitally necessarily means reducing bits of total resolution). In any case, this is easily rectified by using the app to set the startup volume to "fixed" and "100%" (to make sure you are getting all of the resolution from your source), and turn off the EQ.Finally, the value here is a bit of a question mark. If you need a pure digital streaming source, this does the job and is one of the few options on the market at this price point. However, for just a tiny bit more, you can upgrade to the S3 non-Lite and have more flexibility for future needs but with fewer digital output options. Know your system and your needs and choose accordingly.Overall, this is a niche product, but it does what it advertises. But definitely fix the default volume and EQ settings.
g
goodtimesroll
Very Nice with Room for Improvement
I also tested the Fosi S3 in the Spring, so was keen to try it's "Lite" counterpart. The Lite version makes perfect sense to me, as I run all my digital sources through a FiiO R2R DAC, and it seems redundant to have multiple other components with DAC's built-in that I just bypass.The Lite shares the same handsome case and Bluetooth remote control as the S3. It also shares the same smartphone app that allows you to access the more complex functions, like EQ settings.Inevitably any streamer that costs under $500 will be compared to the WiiM line-up, and WiiM still has a number of advantages, like a touch screen display, access to more subscriber services (including Amazon Music), rechargeable metal remotes, etc.But Fosi does have great hardware here and is steadily issuing software updates that improve the feature set. The S3 Lite is an excellent value at the listed price and will be the right choice for many. Recommended!
Jojo la bricole
Impossible de le connecter en wifi avec un tel android !
Impossible de le connecter sur ma box avec mon tel android (samsung Zfold6), que ce soit en 2.4g ou en 5g avec le smartphone bien sur le m��me r��seau et �� 3m de la box alors que tous les autres appareils se connectent sans probl��mes !
J. D.
Der S3 Lite ist eine interessante L?sung, wenn man eine bestehende Hi-Fi-Anlage um Streaming-Funktionen erweitern m?chte. Besonders praktisch finde ich, dass es sich um einen reinen digitalen Transport handelt und verschiedene digitale Ausg?nge zur Verf��gung stehen. Dadurch kann man das Ger?t gut in ein vorhandenes System integrieren. Wi-Fi 6 und Bluetooth 5.3 sind zeitgem??e Standards und bieten flexible M?glichkeiten f��r die Verbindung. Auch die Unterst��tzung verschiedener Streaming-Dienste ist ein gro?er Vorteil. AirPlay 2, Google Cast und Spotify beziehungsweise Tidal Connect decken bereits viele typische Nutzungsszenarien ab. Der 10-Band-EQ ist au?erdem interessant, wenn man den Klang etwas an die eigenen Vorlieben anpassen m?chte. Insgesamt ein kompakter und vielseitiger Streamer f��r alle, die ihre vorhandene Anlage nicht komplett ersetzen, sondern gezielt um moderne Streaming-Funktionen erweitern m?chten.
